Why distributors are not good enough
Posted: Sat Feb 09, 2008 12:34 am
A few quick lessons on ignition theory :
Dwell time:
Spark duration:
Time per cylinder = 1000 ms / ((((X RPM / 2 RPEC) / 60 s) * Y cyls) / Z coils)
Where RPEC = Revs Per Engine Cycle
At 7000 RPM with 6 cyls and 1 coil = 2.85ms
If you subtract a spark time of 1ms then dwell = 1.85ms which is WAY too short. Even assuming the spark is instant, it's still too short really...
So, if you want boost and a dizzy, wheres your effective good ignition zone?
With a 6 cylinder at 7k RPM you can have:
COP just means you allow the coils to stay totally cool working for 1/4 the time or so.
For example, my 4 cylinder with 4 coils : 16ms per engine cycle to do as required, 5ms dwell leaves 11ms for the spark and a nice coffee break :-)
That is why distributors are no good in a high performance application. There are many other reasons such as long leads, caps, rotors, firewall issues with RWD setups.
Here is the formula loaded into google calc ready for you to play with for your application.
http://www.google.com/search?hl=en&safe ... tnG=Search
Dwell time:
- 1ms very weak spark
- 2ms usable spark in SOME applications with decent modern coils (maybe yours)
- 3ms usually enough, coils stays cold, spark is ok
- 4ms enough for most, coils may get warm, spark is good
- 5ms max, full dwell to saturation, coils will get warm, spark is best
- >5ms, part of the time is spent purely as a DC load, this solely heats the coil and does not benefit spark energy at all
Spark duration:
- We'll assume that its 1ms long for point of discussion.
- 3ms dwell to 5krpm
- 4ms dwell to 4krpm
- 5ms dwell to 3350rpm
- 7k 4.7ms dwell
- 7500 4.33ms dwell
- 8000 4ms dwell
