View unanswered posts | View active topics It is currently Mon Feb 24, 2020 12:14 am
This topic is locked, you cannot edit posts or make further replies.  [ 5 posts ]
Soldering Surface Mount Devices - for the average joe
http://curiousinventor.com/guides/Surfa ... dering/101
Found this the other day when I was debating how much trouble a 80pin QFP would be to solder by hand. Gave me a 'no sweat' attitude and hope it does the same for you. Can't wait to get home and try it out!
Sat Apr 12, 2008 6:26 pm
Good video :-) I saw one of the wiping/floating technique on youtube :
http://youtube.com/watch?v=wQXhny3R7lk
Worth a watch also.
I tried it and with no flux and no fancy stuff AT ALL, I could do 0.8mm pitch, but had trouble with 0.5mm. I had no wick to clean up with though. With wick, I could have fixed the small mistakes. It will be cool to do a hand made SMD board later when Cam or Tony or someone designs a nice one for us. I look forward to it :-)
Fri Apr 18, 2008 2:49 pm
I'm teetering on going mostly surface mount on my next board and doing it all by hand. I think it's the only way I'll have enough room for everything!
Fri Apr 18, 2008 2:56 pm
Comments here please :
viewtopic.php?f=24&t=99
Admin.
Mon May 26, 2008 6:44 pm
http://www.zianet.com/erg/ShopSolderPaste.html
He has some nice video's recommending how to use it. My personal preference is to use the paste and an iron, but that's mostly because I'm impatient. Ever since I started using the paste, I haven't been able to go back, and go back I mean to through hole, or SMT w/ solder wire. It makes it so easy if you can get good paste.
Sun Jul 27, 2008 12:39 pm
