View unanswered posts | View active topics It is currently Wed Dec 11, 2019 2:10 am
Reply to topic  [ 5 posts ]
DIYEFI Nexus Down
Just FYI, if you're trying to build OLV from source, you'll have a hard time because the required nexus is down. I've had a look, but there's not a quick fix, sadly.
The real quick fix is to get your OLV from here: http://builds.freeems.org/
If you've already built it recently before the issue popped up, you can add '-o' for offline execution and it should build okay, too. But if you don't have the necessary parts, it'll just fail.
Sat Mar 17, 2018 9:20 pm
Bummer. I sent myself a reminder only a few hours ago to update my build docs. By "the required nexus is down", is it safe to assume you mean permanently?
Sun Mar 18, 2018 4:19 am
False, it's not safe to assume permanently. I was just taking a look and I have some correlation, but no causation, yet:
viewtopic.php?p=43926#p43926
It was the same day, David! https://www.youtube.com/watch?v=K_Ii_IlmrFk
Oh well, at least I have a clue now! Will try to figure out what broke it and get it sorted ASAP.
Sun Mar 18, 2018 9:56 am
Double bummer, the server upgrade wasn't quite as seamless as it should have been. The builds.freeems.org OLV downloads page is currently down! I only found out because I wanted to grab the windows version for my wife's machine to test a high-res scaling theory. Oops. Working on a resolution now. XXOO
Sat Jun 16, 2018 12:45 pm
Fixed! For this one. Not sure what else is broken. Sigh.
Sat Jun 16, 2018 1:01 pm
