View unanswered posts | View active topics It is currently Thu Apr 02, 2020 1:49 am
Reply to topic  [ 2 posts ]
MegaSquirt Links Blocked By Referrer
As most of you know by now, any links to any MegaSquirt sites from this site are blocked by referrer. This is a minor inconvenience imposed by a petty man called Lance.
There is a way around it, but it's not automatic unfortunately...
Just place the following url snippet in front of your link and paste as normal.
Code:
http://anonym.to?
For example :
http://anonym.to/?http://www.msextra.co ... 5&start=20
Thank you for your patience!
Add anonym.to method and remove old method.
Sun Aug 31, 2008 1:22 pm
A small update courtesy of ca7, as of very recently, links to msextra.com and ms3efi.com do not need a proxy under them.
Links to the others including microsquirt.com, msefi.com, megamanual.com, bgsoflex.com still need the above metioned technique to work.
Add ms3 details and which sites require the proxy.
Tue Apr 20, 2010 5:21 am
