Just FYI, if you're trying to build OLV from source, you'll have a hard time because the required nexus is down. I've had a look, but there's not a quick fix, sadly.
The real quick fix is to get your OLV from here:
http://builds.freeems.org/If you've already built it recently before the issue popped up, you can add '-o' for offline execution and it should build okay, too. But if you don't have the necessary parts, it'll just fail.
_________________DIYEFI.org - where Open Source means Open Source, and Free means Freedom
FreeEMS dev diary and
its comments thread and
my turbo truck!n00bs, do
NOT PM or email tech questions! Use the forum!
