I have this project going on running on MS2E using a Holset VGT turbo. I am using a wastegate actuator for the VGT actuation, and an external wastegate for keeping boost down after VGT is fully open.
Now I know that using SD computers anyone swapping turbos, or turbine housings will have to retune to match since it can greatly affect VE of the engine.
My problem comes from having a hotside on the turbo that can vary from a VERY small A/R, to a very large one, and anywhere in between. In Holset's measurements it varys between 3-4cm^2 all the way to 25cm^2.
Currently to avoid tuning complications at WOT and higher boost, I have the VGT opening fully before I would like to, so that at high engine load I have basically a fixed size turbine housing. Greatly simplifying tuning in that portion of the map. This slows my spool down somewhat from where it could be if ideal. It spools VERY quickly to 9-10 psi, then slows down because that is where the VGT is fully open.
My question is:
Is there any way the baro compensation, or something similar could be modified to allow a pressure sensor, a high pressure MAP, etc to measure exhaust manifold pressure and at least somewhat compensate for the resulting variation in VE?
I have another guy who is looking at using a Garrett VNT and MS2 also. I know something could greatly benefit him also.
I have some pictures and information about the turbo here.
http://www.turbotalk.org/bb/viewtopic.php?f=25&t=174
http://www.theturboforums.com/smf/index ... c=120273.0
Here is a MSLV log of the transient response of the turbo with the VGT opening faster than I would like. From 3000 RPM cruise at 70kpa to 9 psi in .9 second, then much slower after that. This response is in a turbo with a GT35R sized compressor on a 2.4l btw.
I would appreciate any feedback on possible solutions to the tuning complication.
*edited for links
