Re: OEM ECU data logger and interceptor idea
Posted: Fri Oct 10, 2008 9:17 am
OK my battery is in the boot so the cable is really quite thick its about 12-16mm diameter core or 95-150mm2 to a large junction block in the engine compartment for the starting, charging and ancillaries circuits and a seperate 16mm2 straight from the battery for the ECU and on-board electronics.
So as standard my car has bigger chunks of copper its just fun to wind you up!
Can't help enjoy a bit of net fishing
