Wouldn't it be really handy to have a single board PIC or MCU based project that intercepts and logs all the data streaming to and from the OEM ECU. In theory you could find out where the crank timing angle is, you could log all parameters and generate OEM base maps to program into your new build FreeEMS and minimise the time it takes to get the system off the ground.
If nothing else it could get you a system that does all the original OEM did, but with one major difference, you can tweak as required and if all else fails and you get it really screwy reset it back to OEM and start again.
Would this not be an ideal tuning tool to encourage newbies to take up FreeEMS and generate massive interest?
Is it some thing that could be programmed into the FreeEMS board to sit there passively learning everything it needs from the OEM ECU building maps and settings based upon your normal and not so normal driving habits?
or is it a job better suited to a PIC based project maybe based around the PIC 18F4525 or similar?
thoughts please guys
