I wanted to keep all the wiring harness totally stock just in case i sell the car at some point and want to remove all my trimmings.
So i used the old wiring and 4 pin O2 sensor connector to access power and signal lines back to the ECU.
What i found was that the sensor does not have any power until the engine is up to operating temperature.
In this instance what I did was make a shorting link between pins 2 and 6 of the O2 relay socket.
This bypasses the relay contacts, and because the power to the O2 relay is controlled by the Main ECU relay is comes on with the ignition and goes off about 5 seconds after the engine shutoff.
I can take pix if anyone is interested and provide diagrams, it started raining today so i had to run in quickly.
