I just had someone tell me the jargon was a bit much. I can see that that is easily true, so I suggested a Glossary thread. Ask your questions here and I'll put the answers in this thread incrementally :
http://www.diyefi.org/forum/viewtopic.php?f=24&t=271
Glossary thread, ask your jargon questions here :-)
shameem
Re: Glossary thread, ask your jargon questions here :-)
ECT-Engine Coolant Temperature [Fred: not on this site, or in ms land that I've seen, here this means Enhanced Capture Timer]
CHT-Cylinder Head Temperature
MAT-Manifold Air Temperature
IAT-Intake Air Temperature
MAP-Manifold Absolute Pressure
MAF-Mass Air Flow
VAF-Volume Air Flow
TPS-Throttle Position Sensor
CPS-Crank Position Sensor
EGT-Exhaust Gas Temperature
EGO-Exhaust Gas Oxygen
VSS-Vehicle Speed Sensor
MS-Mega Squirt
BS-BullShizzle
MAF-Mass Air Flow
VAF-Volume Air Flow
MS-Mega Squirt
BS-BullShizzle
Reason: Added note about ECT
shameem
NB-Narrow Band
WB-Wide BAnd
BB-Bulletin Board
BBW-Dont go there
WB-Wide BAnd
BB-Bulletin Board
BBW-Dont go there
LOL, Thanks man, I'll add those in now :-)shameem wrote:BS-BullShizzle
PCM = Power train Control Module
What manufactures are calling their ecu's now a days as the ecu does more then just engine management these days.
True, or even VCM :-o, scary!
