Bump from the dead, but probably as good a place as any.
Try getting in touch with Baldur of controls.is - his DSL1 device may work for you, but perhaps you'll need to retrofit the injection hardware from another engine to use it. Diesel tech is quite fickle.
You'll find his contact details on his website, here:
https://controls.is/If anyone can help you, it's probably him.
I would say, though, if you can keep the stock ECU to run it, that'd be the easiest route - just need to understand the loom and sensor requirements to trick it into being happy :-)
FreeEMS dev diary and
its comments thread and
my turbo truck!n00bs, do
