View unanswered posts | View active topics It is currently Wed Sep 30, 2020 6:10 pm
This topic is locked, you cannot edit posts or make further replies.  [ 23 posts ]  Go to page 1, 2, 3  Next
NB vs WB
Is it true that NB and WB sensors are the same... and its just the controller circuitry thats different?
Sat Apr 25, 2015 9:42 am
Negative: http://en.wikipedia.org/wiki/Oxygen_sen ... _the_probe
EMStudio
Interesting Stuff
My Car
Tue Apr 28, 2015 10:36 pm
What are your thoughts on "tuning devices" that use a narrow band sensor?. Can a NB be "offset" to measure between, say, 12.0:1 and 13.0:1 ??
Thu Apr 30, 2015 8:49 am
NB i useless except for keeping catalytic converters happy by oscillating them back and forth past stoich...
Thu Apr 30, 2015 12:51 pm
Nope. They're pretty much only useful for an ECU (typically stock, aftermarket closed loop use should WB anyway) to maintain a stoich AFR during normal (not WOT/idle) closed loop operations.
EMStudio
Interesting Stuff
My Car
Thu Apr 30, 2015 12:58 pm
What are your thoughts on "tuning devices" that use NB sensors?
Thu Apr 30, 2015 1:55 pm
That's not really true. They don't maintain stoich, they intentionally oscillate either side of stoich to make the catalytic converter work optimally. If they did want to maintain stoich, they couldn't do that either, swinging side to side is all they can do.
Fri May 01, 2015 1:30 am
I don't think thats true. The only reason they swing back and forth is because of the OEM ECU, isn't it?. Im pretty sure they could stabilize an output if the AFR was stable at stoich.
Fri May 01, 2015 7:48 am
Then you clearly don't understand how narrowbands work. Sorry I couldn't explain it to you.
Tue May 05, 2015 8:41 am
I have some idea. Why would the output swing back and forth... rich and lean... if the AFR is constant??
Tue May 05, 2015 9:13 am
