Page 6 of 6
Re: My open source Wideband Controller, SLC Free
Posted: Sat Jun 07, 2014 8:55 pm
by pishta
JHC, you can almost make a DIY 3D printer for that! This should be Fred's next project...
http://www.instructables.com/id/Make-a- ... led-parts/
or just buy this...
http://www.mpja.com/350in-X-137in-X-118 ... 6283%20BX/
Posted: Fri Sep 19, 2014 7:12 am
by towbar
I think you will find the box you just suggested is too small inside to fit the pcb.
There are larger ones available of course. Cheap on Aliexpress or Ebay
Jeremy
Posted: Sat May 23, 2015 1:32 pm
by Klassikovod
Hello ! This project is now closed or has become completely commercial ? All files for the repetition of the device removed ?
Posted: Thu May 28, 2015 12:54 am
by DonTZ125
you mean
these files, on his site, under "Support / Software and Documentation", and linked to from his SLC product page?
Posted: Thu May 28, 2015 6:13 am
by Klassikovod
Yes. Perhaps they are. Let me see . Thank you !
As a kind of looked up and not for the first time on this forum before I enjoyed.
Posted: Thu May 28, 2015 7:08 am
by Klassikovod
I just could not find the information ... I have the device interface to connect to a PC via USB or COM-port?
Posted: Fri May 29, 2015 11:15 pm
by Nige
Posted: Thu Jun 11, 2015 4:57 pm
by russian
toalan wrote:
You can get the source files here,
https://github.com/toalan/14Point7.com_SLC_Free
I release this project it under GLPv3.
SLC Free only supports the Bosch LSU 4.9 sensor
There is a closed version that only supports the 4.2
Are there any plans to make 4.2 edition open? I know the source code is still available at your website, but I am wondering if you would be willing to ask questions on the code / add more comments into the code?
Posted: Sat Jan 16, 2016 12:27 pm
by toc
What acceptable alternative to the CY8C24423A-24PXI is there?
In my travels for that chip, I'm reading on sites to source that chip that is No Longer Available?
Posted: Mon Jan 18, 2016 11:29 pm
by DonTZ125
The 28-pin DIP (through-hole) -24PXI is definitely "End of Life"; Digikey has 46 and won't order them past the 6th of July. Mouser has >1000 on the shelf, so there's still time to order some in.
The 28-pin SOIC (SMT) -24SXI is apparently still going strong, and is the easiest of the SMT IC packages to hand-solder. The 28-SSOP -PVXI is also still in production, and can also be hand-soldered (with a little more care).
If you are working with a pre-designed board that uses the DIP package, SOIC-to-DIP adaptors are readily available.
