My open source Wideband Controller, SLC Free
Author |
Message |
flat4power wrote: just a question, is it compatible with E85? Yes, of course :-)
Thu Jun 06, 2013 8:59 am |
flat4power
Joined: Mon Sep 24, 2012 8:19 am Posts: 100 Location: France
good for me because I would use E85 for my engine
Mon Jun 10, 2013 11:06 am |
Tsanten
TO92 - Vaguely active
What change will take for a lsu 4.2 ?
Thu Jul 04, 2013 8:44 am |
Tsanten
This could work with a lsu 4.2 ? I saw that the pcb has R7 to deal with but the software can ?
Thu Jul 04, 2013 3:39 pm |
toalan
Wideband Wizard
Joined: Tue Jun 10, 2008 2:53 am Posts: 241 Location: Toronto Canada
Finally got around to finishing this up, everything is now done and tested. I will put up a new git repository with the completed files later this week.
I am going to offer 3 different kits:
SLC Free A: open source, LSU 4.9 sensor only, LCD displays lambda and sensor temperature as bargraph, $35 USD SLC Free B: closed source, LSU 4.9 sensor only, LCD displays lambda and sensor temperature as numeric text, $45 USD SLC Free C: closed source, LSU 4.2 sensor only, LCD displays lambda and sensor temperature as numeric text, $45 USD
_________________www.14Point7.com
Mon Oct 28, 2013 10:58 pm |
Hentai
I take it the baragraph doesn't tell you anything but how far its from one side of the range to another vs the numerica text saying what its current temp is?
Tue Oct 29, 2013 3:04 am |
DonTZ125
Joined: Tue Feb 12, 2013 5:43 am Posts: 57 Location: Scarborough, ON
Will the SLC-Free be able to use I2C?
What is the accuracy difference between the SLC-OEM and SLC-Free?
Mon Dec 09, 2013 5:27 pm |
toalan
Wideband Wizard
Hentai wrote: I take it the baragraph doesn't tell you anything but how far its from one side of the range to another vs the numerica text saying what its current temp is? The bargraph is actually pretty decent, there are 80 columns so and each column represent 0.01 lambda increments. What I will try to do is make a paper template that you can cut out and paste onto the display PCB which will give you visual cues on where along the column represents what lambda value.
Sun Dec 22, 2013 8:28 am |
toalan
Wideband Wizard
DonTZ125 wrote: Will the SLC-Free be able to use I2C?
What is the accuracy difference between the SLC-OEM and SLC-Free? I do not do any calibration on the unit, so SLC Free is at the mercy of component tolerances and the analog system on the PSOC uC. For SLC OEM, all units go through quality control, and I do some calibration on them before they ship out, so I am 100% confident that it is 0.01 lambda accurate. For SLC Free I have built about a dozen of them over the course of development, and 70% is 0.01 lambda accurate, the other 30% is in the 0.02 lambada accurate range. I2C is not supported by SLC Free
Sun Dec 22, 2013 8:39 am |
pishta
Put me down for a B/C kit, whats the difference? Where do I send the money? very Cool.
Wed Feb 26, 2014 3:24 am |
Who is online |
