The spindle motor already had one indentation drilled so I needed to add 6 more to make 8-1 trigger wheel.
I printed out a template on to a sticker so that I could centre punch the location of the indentations.
Next I taped up the opening of the motor. I didn't do this the first time and the metal swarf got under the motor and jammed up the movement.
I then drilled the indentations.
I put the motor back into the housing and wired it up.
You can spin the motor by hand or use a drill to drive it.
I might be hard to find a hard drive like the one I used. You may be able to use a newer hard drive and glue small magnets on the platter to make the teeth.
