Page 1 of 1
question on LH jet
Posted: Sun Nov 27, 2011 5:33 am
by alfaromeoguy
hello i am posting here, new guy
.. but i need some imformation on bosch LH -jet, i have a 1984 alfa romeo spider, with L-jet.. and plan to replace it with LH - jet 2.2 system. i have all the parts, but a few questions.. can i use a ' stand alone ignition system? and can i bypass the idling valve? thanks for any help here..
Re: question on LH jet
Posted: Sun Nov 27, 2011 3:59 pm
Welcome! :-)
alfaromeoguy wrote:can i use a ' stand alone ignition system? and can i bypass the idling valve? thanks for any help here..
I'm only guessing, but I'd be surprised if you couldn't use a standalone ignition system. As for the idle valve, what do you mean by bypass it, and what do you want to achieve?
Posted: Sun Nov 27, 2011 5:50 pm
by alfaromeoguy
on the idle valve is this just on the LHjet or doe's it need to work with the stock volvo igntion? my L-jet stock feul injection system cannot handle the up-rated engine , i start to lean out at 4600 rpm.. due to the limitations of L-jet.. thats why i am trying to put on lh-jet on my car i have a sytem off a 1986 volvo 240 sedan..
Posted: Mon Nov 28, 2011 2:45 am
Sorry! I replied and forgot to authorise the post...
I'm unfamiliar with and unsure about the systems that you're talking about, unfortunately. Perhaps someone else can help. You might be in the wrong place for L-Jet help, though.
Posted: Mon Nov 28, 2011 3:33 am
by alfaromeoguy
what area do i post l and Lh jet questions?
Posted: Mon Nov 28, 2011 10:36 am
This one is fine. What I meant is that the people here are focussed on non-OEM solutions and will only happen to have knowledge of those systems. If you approach a community dedicated to the cars that those systems came from, you'll find that they know the intricate details of them and will be better able to help you. Make sense? :-)
Posted: Wed Nov 30, 2011 7:31 pm
by thebigmacd
alfaromeoguy,
You will probably have better feedback if you post questions about your Volvo LH jet system at
http://forums.turbobricks.com
Posted: Wed Nov 30, 2011 10:26 pm
by alfaromeoguy
quick reply form turbobricks.....????? i asked them the same question 5 months ago, yet to see a reply.. thanks
Posted: Fri Dec 02, 2011 1:06 pm
Perhaps bump the post? Good luck!
