Alot of people including myself wonder about the role these play.
So I will dummy up and ask some questions,
hopefully someone can come back with some easily understood answers
 .First why do you need them? non efi engines dont use them normally its just 12volt - coil - points- ground.
Whats the igniters role?
Do all igniters convert 12volt DC to AC voltage? lately Im reading how XXX brand igniters run at 850 to 1200 hertz
Do all ECU/EMS's require igniters and why? I thought the Bosch BIP373 Coil Driver transistor were all you needed for trigering.
if I have COP's /wasted spark /(add your own flavor here) Do I need them?
explain the difference between CDI and igniters
more to come but that will do for now
regards Paul
