Water injection on N/A engines
Posted: Tue Sep 22, 2009 12:23 am
Hey guys,
I've been lurking here for quite a long time now. Unfortunately the development here at this stage is out of my league, so I won't be of any help code- or electronics-wise. I am however very interested in converting my 1980 Mini Clubman Estate from HIF44 Carb to FreeEMS some time in the hopefully-not-too-far future
You guys are doing a great job, especially now that a good pace has returned.. Thanks for not giving up!
Now aside my introduction, I wanted to bring up a subject that's not so commonly implemented, but which I'm very curious about:
Water injection on naturally aspirated engines
I've given this some thought and a few calculations on my own, to see how much power/fuel saving could actually be gained. Hope you don't mind numbers.
The ratio water expands when converted from liquid to steam is about 1:1800. So 1ml of H2O will turn into about 1.8ltrs of steam.
I concluded that roughly 1g of fuel could turn about 16g of water (80°C, pre-heating assumed) into 28.8ltrs of steam (140°C, higher boiling temperature due to high pressure in combustion chamber).
Now the calculations get hard on my head, since I'm not dealing with VE tables all day like you guys (yet).
If my understanding is right, a 500cc 1cyl engine gets about 400ml of air at 80% VE. At stoichometric this would mean 0.035g of fuel per charge. If 30% of the heat could be used, about 0.18ml of water could be turned into 315ml steam.
I don't know, sounds enough for me to be worth a try. I would think something like that could happen too, enhancing the gasoline flame front, cleaner combustion too.
Don't get me wrong, I'm not very eager to try this on my Mini, but for example power generator units could profit from this, if it works as intended.
Of course I have concerns about vapour blow-by at the pistons, or corrosion from superheated steam, fouled plugs, and a ton of other things. Still the idea is chewing up brain time, so I needed to get it out for public review
What I'd love to see to make this happen with FreeEMS is a second VE table for the water injector. This could be useful for other applications too, like switching between LPG and gas (or mixing both?). I haven't looked at the code, neither would I understand it. So I'm just humbly asking to maybe keep this feature in mind.
Thanks for reading, now input please. Anyone ever used water injection on N/A engines?
Greets from Germany, Stefan
