Hmmm spark inquiry
Posted: Sun May 10, 2009 9:18 pm
I just wanted to toss out a note relative to spark checking during operation. I think that feature would be very handy and I would really hope to see it in 2.0.
I'm fighting with my wifes O1 Jetta. About 2 weeks ago it developed a skip, and I'm sure the problem is a weak spark. Figuring out which cyl and why is a different story. Even worse, it's intermittent and may be happening on multiple cyls. When I say intermittent I mean it happens with in 5 minutes, but that's several hundred rotations of the engine, so intermittent.
This is the 1.8T with 4 coils. They sit directly on the plug in the head, no plug wires. VW ran 12V level signals to them and that's it. About 6 months ago or so, cyl 2 had a complete, out of the blue, no warnings, failure. Simply didn't spark at all. I replaced the 4 plugs, the old plugs looked fine (cyl 2 a bit gas wet, but fine) light brown color, no erosion, no carbon deposits, and compression was spot on for each cyl. I was looking for a reason for cyl 2 spark failure. I had to claim the coil simply went junk. Because I felt the coil simply went junk, I replaced all plugs and coils. So I have three good and one bad in the basement, with new equipment in the car.
If I really push it, I can get PO300 (multi miss fire) P0301 (cyl 1 miss fire) P0302 (cyl 2 miss fire) up to P0303. However my wifes driving does skip, but doesn't toss codes. My feel is that the skip is a lack of ignition, not a miss fire. When I drive, the skips cause miss fires on other cyls. I see no reason why timing would an issue, so I believe it has to be a weak spark, not a timing issue. I also see no reason for being concerned about compression, it was spot on 6 months ago. So I'm left trying to figure out why it wouldn't ignite.
So now I'm left trying to figure out how hot the spark is, when I have no tools to figure that out. Perhaps someone has some recommendations. Perhaps I can scope the 12V lines, or measure magnetic flux or something. I know that as soon as I take it out of the bore, it's not the same environment as when it's running so I feel I can't trust it's color when it's on top of the block. I guess I can try, if it's not a nice blue spark, then I can replace it with one of the originals. However, I suspect they won't be blue when out of the bore.
