View unanswered posts | View active topics It is currently Thu Feb 20, 2020 5:18 am
Reply to topic  [ 38 posts ]  Go to page Previous  1, 2, 3, 4
Tools You Wish You Had
Lots of other new tools between the last post in early January and this post from last night. Will try to fill out some posts at some point over winter.
https://twitter.com/FredCookeNZ/status/ ... 6517607430
This hammer is intended for separating the rod caps for the Volvo 500+hp build. Hopefully I can try it out soon! :-)
Sat Apr 28, 2018 9:29 am
The name of the hammer is the best part!
Sun Apr 29, 2018 11:06 am
Thor mythology, hammer wielding god, ~1900+ years old
Thor hammer company, ~120 years old
Thor character, ~60 years old
Sun Apr 29, 2018 11:57 am
Now he has axle!
Sun Apr 29, 2018 7:38 pm
Tool acquisitions minimal recently due to a lack of funds from a wayward wife...
But, grabbed a deal on a set of reciprocating blades with a pouch: https://twitter.com/FredCookeNZ/status/ ... 2859670528
Image Image
And finally bought myself a jump starter pack, top of the range, on special, trade special, 485nzd ish, inc 15% GST.
But I'm a bit unhappy with the marketing department of the company that makes it, as you'll see if you can do simple math:
https://twitter.com/FredCookeNZ/status/ ... 6279790593
https://twitter.com/FredCookeNZ/status/ ... 8491566080
https://twitter.com/FredCookeNZ/status/ ... 2903755777
https://twitter.com/FredCookeNZ/status/ ... 0857764865
And the acid test, hotel had a flat battery, managed to log both the before (flat, cranking, slowly, stalling) and the after (Project IS1500 hooked up and spinning over at a healthy 200 RPM odd).
https://twitter.com/FredCookeNZ/status/ ... 1852286977
I actually went out with intent to disconnect battery and try it, but that wasn't necessary! :-D
Scales in both windows are:
BRV 5 to 15
RPM -100 to 700
Primary -1 to 50
Specs from the logs are:
Failed start:
Prior voltage: 12.26V
Peak dip down to: 5.44V
Post cranking recovery: 9.98V
Description: Cranking sluggishly and briefly before stalling and key relaxed
Jumped start:
Prior voltage: 13.22V
Peak dip down to: 10.86V
Stable cranking @200+RPM: 11.01V
Post cranking, pre alternator: 11.7V
Post cranking on charge: 13.24V
Description: Cranking vigorously and happily, slow start due to lack of prime for max stress test of jump start device
Less than an hour later I went to start the Suzuki, same deal! Drained. That battery is in good shape, unlike the 5+ year old hotel one, but gets low if left with the alarm connected for ages.
Sun May 20, 2018 11:29 am
Criss crossed for the hotel: https://twitter.com/FredCookeNZ/status/ ... 2033284097
Mon Jun 11, 2018 9:29 am
Dewalt battery collection upgraded with two 600 gram 4AH 18V units for the drill and impact driver - I'll continue to use the 6AH 54V/18V flexvolt batteries on the big rattle gun and big 54V recrprocating saw. Tweets/pics, out of date yet again TODO:
Desires from yt watching binge:
1) Automatic centre punches, in particular Starrett 18-A and/or 18-C and/or 18-AA 35 - 60usd each depending on size on amazon - US made
2) Magnetic welding tools like https://www.amazon.com/Welding-Magnet-M ... 073Y51NZB/ and https://www.amazon.com/MAG-MATE-WS11094 ... 019Z09D8K/ and https://www.amazon.com/Strong-Hand-Adju ... 0147D5VOA/
3) Ratcheting Flare Nut Wrench Set: https://www.amazon.com/Stanley-Proto-J3 ... B01H2Z0VNQ and http://www.protoindustrial.com/en/indus ... ench-Set-/ latter link shows sizes
Didn't even know those last ones existed, but saw a girl in a video using one badly and now at some point I'll have to get a set, beats every other bad option I ever used. Can't think how many broken spanners and damaged nuts I've caused by not having them.
Sun Jul 15, 2018 3:05 am
Man this thread is many deliveries out of date, but here's a recent NZ made addition: https://twitter.com/FredCookeNZ/status/ ... 6272649217
Evacut M99 drill bit set, 0.1mm increments from 1.0 to 10.0 and then 0.5mm from 10.0 to 13.0 plus 10.9, 11.9, 12.9 sizes. Stoked.
Mon Jul 22, 2019 1:21 pm
