I plan to post stuff I don't have here, on the basis that I want it. So that when I next have some funding I can look through and go "this one" and improve the situation a little.
What am I missing, off the top of my head, at least these:
- Really good low profile jack, in particular: DK13HLQ http://www.ac-hydraulic.dk/en/products/ ... s/dk13hlq/ which is about 1knzd on http://www.sulco.co.nz/AC-1-3-TON-HYDRA ... -JACK.html
- A good hydraulic press, whatever good is - 300+? DIY could be less. Volvo bonnet springs could be useful. EDIT: viewtopic.php?f=15&t=2750
- A nice set of quality kiwi drill bits and a drill press to go with them
- A decent AC/HF TIG setup inc self-owned bottle
- A decent light alloy jack for track day/mobile use - do *good* alloy jacks actually exist? Mostly junk, I think. EDIT: Found this Torin: http://torinjacksusa.com/bigred/bigred- ... -jack.html
- Lithium cordless tool kit, including angle grinder, drill, 1/2" impact driver, and various other units
- Bearing puller kits, stud remover kits, etc.
- Deep reach 3/8 drive set from 8 to 21 or so.
- Set of hex drive sockets, similar to my torx sets
- Oil filter cup set
- Leak down tester
- Compression tester - what happened to my one??? :-p EDIT: Got one: viewtopic.php?p=43789#p43789
- Brake power bleeder setup
- A maximal single phase air compressor with NO leaks and a big vertical storage tank attached to it, 10CFM for spraying, 20 for die grinding, 15.5 seems maximal @ 1500 bucks or so
- Bead blaster cabinet. EDIT: Going to get a gravity feed Ampro A3714 blaster, and try some soda and other stuff through it on various tasks.
- Parts washer with pump/tank/filter
- A real scope with decent functionality
- Some dollys or wheel dollys to abuse/misuse
What do you wish you had?
