View unanswered posts | View active topics It is currently Mon Feb 17, 2020 2:43 am
Reply to topic  [ 3 posts ]
Strut Braces - post winners, and failures
I've been studying these a bit lately too, and come to the following conclusion: https://twitter.com/FredCookeNZ/status/ ... 7740062720
Which is a disappointing one, to say the least.
So, what form should they take? What style should they NOT have?
The Good
What it's like when it's right and doing a good job of keeping the suspension geometry aligned.
  • Straight across, in BOTH axes!
  • Low down to strut top plate and/OR
  • Strut top plate bracket and fasteners must be rigid and strong
  • Light weight bar - no bending moments, only compression/extension
  • Triangulation to firewall centre IF sufficiently far away and not otherwise - in fact, if the strut towers are very close to the firewall, why bother at all? :-p
Seems easy, right? Seems not, if you look around...
The Bad
What it's like when it's bad and not doing much except adding weight. In order of popularity! :-p
  1. Bar is bent in one or both axes. Fail. Not stiff, likely to allow the movement it was designed to prevent. Purpose not achieved. Very popular failure...
  2. Bar is a frame, hugely overbuilt, not light, commonly combined with the above for maximum irony.
  3. Strut top plate brackets inherently weak [1] from insufficient plate coverage. Eg, plate 200mm wide, brackets only pick up half of this, or less
  4. Strut top plate brackets inherently weak [2] from insufficient triangulation/strange angles
  5. Triangulation added to firewall when angles are very shallow - minimum benefit, if any, likely an overall loss for the weight
  6. Triangulation picks up weak area on firewall that can't support anything - no benefit, possible damage
And there's just acres of these bad strut braces around. Unlimited choice, as we'll see when the images start rolling in.
Reasoning
If the bar is bent it cannot be stiff. This one's obvious, despite being the biggest failure. To have it stiff/strong after being bent it would need to be high/thick. It can't be, there's an engine in there somewhere, and a bonnet/hood above.
If the distance from the bottom of the strut top plate to the attachment point is half the lateral distance from the outer most strut stud to the inner most strut stud, you're going to experience 50% of the lateral force lifting up on your nut trying to strip the thread. Whereas if the bar mounts down on the plate very close to the surface, then the force is purely in sheer, and counteracted by the friction joint held in place by properly fastened nuts. If the height is the same as the stud spacing, the force is equal. If there's any point in using a strut brace at all, then this force could be significant and you don't really want it trying to break/loosen your fasteners.
Challenges
Something must be motivating these failures, right? It's pretty obvious again:
  • Engine is high
  • Strut tops are low
  • Bonnet/hood is close to strut tops on the outside/low on the outside, and bulges over engine in the middle
In the third case, there's nothing much to do except put the bend in it and hope it does something. Except maybe triangulating into the firewall instead/as well.
In the first/second cases, one can raise the mounting points on the top plates in a rigid and strong fashion and run something straight, or close to straight.
The compromise between sheer loads with a non-stiff/bent bar and levering loads with a straight bar up high would need to be made on the basis of calculations and/or actual testing. So now I'm wondering "Who am I to assume those calculations have not been made?", which is probably a fair synopsis at this point.
Post pictures of strut brace setups you consider good/bad and your reasoning why. I'll drop some in as I feel the need, but not right now as I need to make some progress on some other stuff.
Tue Aug 02, 2016 5:44 am
Dont have pictures at the moment, but here's my take on strut braces:
Bad:
-Any strut brace that bolts the bar to the mounting plates on a single pivot.
Reasoning: allows tops of struts to move relative to the chassis legs.. missed opportunity.
Semi bad:
-Adjustable bars. Loss of strength and rarely met anyone whoe knows if it's tension or pressure you want to dial in.
I built myself a strutbar for my volvo 360.. low strut tops, high engine, so an angled bar was necessary.
Used 2mm walled pipe and even thicker mounting plates.
Had one of those adjustable flimsy numbers on my AE86 and didnt notice any difference, although friends of mine
swore they could feel an improvement. My guess is that butt-dyno results are usually relative to the amount invested.
If you want to feel a difference, you probably will.
FABRICA MI DIEM, PVNC!
Tue Aug 02, 2016 8:28 am
Fair call re your first point. I wonder how much that matters, though. Hmmm.
Re second point, my assumption is that you want to lock it still as it sits on flat ground. However adjustable bars have a point on some cars. Volvo 240 for example the struts are adjustable in their position, so either the plates need slots, or the bar needs to adjust to move with the plates.
My Type R Lantis came with a factory rear strut brace. I removed it for practicality reasons and never noticed anything and can still take corners pretty damn hard in it :-)
Before I engineer a brace for any of my fleet I will be engineering a rigid bar with a scriber on it and going for a thrash to see what range of movement actually occurs.
Tue Aug 02, 2016 12:18 pm
