Fred's Fleet Maintenance Diary
Posted: Mon Jul 11, 2016 5:33 am
I was trying to do this in a spreadsheet, but that was a little onerous. Currently several are overdue for oil/filter, one less than this morning, which I ticked off today. Most are overdue for brake fluid. Many are overdue for coolant. Let's not even talk about power steering and transmission/diff oils.
Standard maintenance items for me are:
Stagea
Not usable, no maintenance.
54 VW
Will post with each action and update relevant bits above. Comments welcome, argue with my logic anytime :-D
- Oil/filter 5kkm to 10kkm depending on usage and quality
- ATF - on purchase with synth, 20kkm thereafter? 50kkm thereafter? No idea, really.
- Brake fluid on purchase, 2 yearly, with pad change, or before/after track day/heavy hot usage
- Coolant - on purchase, 2 yearly thereafter
- Gear box oil - on purchase with synth
- Diff oil - on purchase with synth
- Power steering ATF - on purchase with synth
Stagea
ATF needs replacing for cold shifts< took another look, looks clean and pink and smells normal. Likely quite fresh. Shifts are actually fine, it's power mode that causes the issue no matter the temperature.- Brake fluid looks OK, but should be flushed EDIT: 12th July 2016: Rear circuits were flushed through, right rear got fresh, left rear got it from the reservoir
- Brake rotors need a skim and better pads EDIT: 12th July 2016: Rear pads replaced with these: https://twitter.com/FredCookeNZ/status/ ... 0871537664
Coolant looks OK, but should be changed< took another look, looks bright and green as it should, not going to touch this for another year or two, let's call it 2 years from purchase, which was now 8 months ago, so in 16 more months, or early May 2018.- Power steering ATF should be replaced
- Diff oil can stay as is, diff upgrade pending
- Fresh oil and filter at 230740km/11th July 2016
- Front rotors need replacing and moderately good pads putting on!
Brakes in decent shape Oil and filter change overdueEDIT: 14th July 2016: Oil and filter done at 295k km, HPR10 highly refined mineral.ATF and filter need replacing for cold shiftsEDIT: 29th December 2016: ATF flushed with ? . Pump dry, top up, pump dry, top up, repeat until not grubby any more!- Brake fluid partially OK, but should be fully flushed
- Coolant dilute, water pump seal needs replacing, coolant reconcentrated
- Diff oil ancient, but diff upgrade pending
- Front tyres shake a little, should be moved to back and destroyed/replaced, pending diff upgrade
- Transaxle oil level low and oil old, good oil on shelf, procrastination in progress
- Oil and filter change overdue, but liquid gold installed, so not overly worried
- Coolant is stop leak, but nothing can be done until head comes off
- Brake fluid unknown, should be flushed
- Front rotors warped, skim or replace, and better pads
- Rear brakes binding a little, free up and maintain
- Electric power steering, figure out how to lube this so it feels good
Rear main seal pissing oil out at a great rate. Replace with new trans install. Sigh.< wrong, was blocked flame trap as per all volvos ever...Oil and filter change overdue, but condition not bad due to most kms = road tripsEDIT: 13th July 2016: Oil and filter done at 306k km, HPR10 highly refined mineral.- Brake fluid should be flushed through, unknown condition
Coolant looks old, but is still green, should be changed soon< Dumped 14th Jan 2017, to be filled 15th Jan 2017, changed again early 2019 or sooner with engine build.- Power steering ATF should be replaced
- Brakes OK but pad upgrades always nice...
- ATF full synthetic, no need to change, but filter probably very dirty, and first gear noisy, change entire trans
- Diff oil full synthetic 80w140 - no plans to change, will reuse in caravan axle when diff gets upgrade
- Power steering ATF should be changed
- Brake fluid flushed when I bought the car, change late 2017 or with brake upgrade
- Coolant fresh and good, but not high quality variety, change late 2017 or with new engine
Oil change overdue, pending engine swap, hence delayed< Done, see post below.- Transaxle oil is synthetic and good
- Coolant is water, radiator is knackered, change to green on upgrade
- Brake fluid is OK, changed a few years ago, change with pads.
- Oil on continuous change cycle for now :-p
- Power steering ATF unknown, change if bothered
- Gearbox oil never changed, but topped up with fresh stuff a couple of years ago
- Diff running non-synth 80w140 - upgrade if funds permit
- Brake fluid unknown, change ASAP
- Diff oil unknown, upgrade before next serious usage
- Gearbox oil unknown, upgrade before next serious usage
Oil is dirty, change before next serious usage< done some time ago, check KP thread and/or twitter, zero miles since change, needs thinner oil or less oil, suss out once driving again.- Coolant is water, but drained, dry now, radiator stuffed, upgrade, then fill with coolant
- No power steering! :-D
- Oil filled with coolant
- Coolant filled with oil
- No power steering yet
- Diff filled with who knows what, and who cares
- Trans filled with who knows what, and who cares
- Brake fluid should be changed with brake upgrade soon
54 VW
