View unanswered posts | View active topics It is currently Sat Feb 29, 2020 10:30 am
Reply to topic  [ 19 posts ]  Go to page Previous  1, 2
Fred's Fleet Maintenance Diary
Dirty milky slime green old coolant dumped from the gold 240 wagon: https://twitter.com/FredCookeNZ/status/ ... 8613841920
And flushed through with water twice (yet to dump the second lot) and hoses off to clean around the fittings which were a bit crusty: https://twitter.com/FredCookeNZ/status/ ... 5196538881
It's not often that I use the HDR feature of the N5, but when I do it's because of excess contrast in a tstat housing. :-/
Will pull the drain cock on the block in the morning and dump it out fully before refilling with a nice 35% blend of fresh nulon coolant. Yay.
Sat Jan 14, 2017 9:36 am
Forgot to take a snap of the cleaned up housing, but it doesn't matter much, that SOHC head is on borrowed time :-D
Fresh coolant in after another flush and a proper drain through the drain cock I didn't know these engines had: https://twitter.com/FredCookeNZ/status/ ... 0674894848
Next coolant change: In with the DOHC setup :-)
Sun Jan 15, 2017 10:27 am
Not much maintenance in some time, but a bunch due now or soon. Got started last night with the Stagea, now running high-end pure PAO/Ester group 4/5 synthetic Penrite oil with lots of zinc and no shearing effect. So I want to get bypass filtration onto it, and the others, so can leave the good oil in 20,000km instead of a mere 5000km, as that seems like a waste for something that doesn't really get degraded by use.
Processed used, and mileage done at:
https://twitter.com/FredCookeNZ/status/ ... 0266087425
https://twitter.com/FredCookeNZ/status/ ... 1971045376
https://twitter.com/FredCookeNZ/status/ ... 6202195969
You may notice the difference between cambelt done and current kms on clock... and it's making a slight noise... so I'll be doing that soon. Damn it.
Also, ATF has been working hard recently and needs to be flushed and filled with good synthetic ASAP. Was red, now reddish brown, smell is not full burned, but it has been hot, that's for sure.
Wed Jan 10, 2018 1:03 am
Stagea ATF flushed through, same mileage as above, tweet tweet: https://twitter.com/FredCookeNZ/status/ ... 7130670080
Thu Jan 11, 2018 10:23 am
Saturday:
240 and 740 both populated with Penrite PAO Ester 10w60 true synthetic (not like Mobil1 junk, cough cough). And a spill, oops.
Tweets/pics:
https://twitter.com/FredCookeNZ/status/ ... 8995467264
https://twitter.com/FredCookeNZ/status/ ... 6954472448
https://twitter.com/FredCookeNZ/status/ ... 8973824000
Two more cars needing bypass filtration!
Sunday:
Speedo fix for 740
Cam belt inspection session on Stagea (OK!)
Crank angle sensor fix on 940
Caravan lightweight axle progress
Sun Jan 14, 2018 11:27 pm
Going oil shopping tomorrow:
5 * 40 = 80w140 pro synth diff oil (all RWD diffs)
10 * 60 = 15w50 or 20w60 PAO Ester engine oil (full zinc/ZDDP)
2 * 40 = 70w75 GL4 Plus pro synth mtx oil (Volvo 360 and KP J160)
2 * 40 = 75w90 GL4 Plus pro synth mtx oil (ute/rx7 box)
150 = 20l of ATF FS for stock
70 = Another 28 cans of degreaser
60 + 20 = 5l + 1l of 15w50 or 20w60 PAO Ester engine oil FOR ROB/R33
2 * 40 = 2.5l + 2.5l of 75w90 GL4 Plus pro synth mtx oil FOR ROB/R33
40 = replacement diff oil from ROB for me :-)
200 + 600 + 80 + 80 + 150 + 70 + 80 + 80 + 40 = 1380 - 200 (Rob) = 1180
Or something like that.
Fri Mar 02, 2018 12:29 pm
https://twitter.com/FredCookeNZ/status/ ... 9029378048
The recently resurrected Volvo 240 Sedan has the following on it:
1) New mineral ATF in power steering https://twitter.com/FredCookeNZ/status/ ... 4295022592
2) New mineral ATF in auto trans https://twitter.com/FredCookeNZ/status/ ... 5091596289
3) 15w40 diesel oil in engine + big Z9 filter https://twitter.com/FredCookeNZ/status/ ... 1347766272
4) nulon lifter cleaner bottle in engine https://twitter.com/FredCookeNZ/status/ ... 0461700097
Diff oil upgrade is pending, but will be 80w140 penrite race/synth for sure.
Thu Mar 22, 2018 10:47 am
Hit 230000km in the 940 wagon today, just a few km after a flush and refill with Penrite PAO Ester 10w60 good stuff. If I can get some bypass filtration on it, I won't change it out for 20k km. I'll just do full flow filters every 5k km and top up.
The other thing I'll do is save the "dirty" oil for processing into clean oil again, rather than flush it out and discard it. One of our forum members uses used oil in his diesel truck state side, and has had bad experiences trying to burn synthetic oils in used condition - ie, the oil is still fundamentally good.
https://twitter.com/FredCookeNZ/status/ ... 1598380034
Sun May 20, 2018 7:37 am
Hotel got inhibitor installed, but the dodgy way, ie, straight in the empty overflow bottle hoping for cycles to suck it in and mix it...
https://twitter.com/FredCookeNZ/status/ ... 2191105027
Sun May 20, 2018 11:38 am
