View unanswered posts | View active topics It is currently Sat Feb 29, 2020 9:44 am
This topic is locked, you cannot edit posts or make further replies.  [ 47 posts ]  Go to page Previous  1, 2, 3, 4, 5
Building 2 350/650hp 16v B230F redblock Volvo engines
A new page and a new title for the old thread. More reflective of current plans :-)
Did no car stuff yesterday except talk to Rob and poke around the garage briefly, and felt bored this morning on the bus ride the city, so tonight I had to achieve something...
Links for ref:
https://twitter.com/FredCookeNZ/status/ ... 9655512064
https://twitter.com/FredCookeNZ/status/ ... 2093489152
https://twitter.com/FredCookeNZ/status/ ... 9465925632
https://twitter.com/FredCookeNZ/status/ ... 8672496641
https://twitter.com/FredCookeNZ/status/ ... 4302428161
https://twitter.com/FredCookeNZ/status/ ... 0307708931
https://twitter.com/FredCookeNZ/status/ ... 4091762689
https://twitter.com/FredCookeNZ/status/ ... 9638837253
https://twitter.com/FredCookeNZ/status/ ... 6346542080
https://twitter.com/FredCookeNZ/status/ ... 0735022080
https://twitter.com/FredCookeNZ/status/ ... 1539209217
https://twitter.com/FredCookeNZ/status/ ... 0743212033
https://twitter.com/FredCookeNZ/status/ ... 3296286721
https://twitter.com/FredCookeNZ/status/ ... 3610412032 (2)
https://twitter.com/FredCookeNZ/status/ ... 0417837056
https://twitter.com/FredCookeNZ/status/ ... 1327439873
Pics:
Fri Nov 10, 2017 11:21 am
To lighten the picture load per page I'll post again with a TODO list for the block strip:
1) Drain oil from sump into tray and transfer to bottle for disposal
2) Remove rear main seal housing and seal with it
3) Remove front cover/oil pump
4) Remove front studs
5) Turn upside down and remove the sump
6) Remove the rod bolts carefully
7) Remove the pistons and rods carefully, clean, oil, and box/bag up for later use
8) Remove the main caps
9) Remove the crankshaft for comparison with B230F crank
10) Replace the main caps, for now
Hopefully I can get the bulk of that done before the weekend is out :-)
Might use the bare block to size up some 240 sedan mounting in an easier way than trying to drop an entire B234F in there...
Fri Nov 10, 2017 11:30 am
Only got 1 and 2 done, and some clean up around it. Then went and got the Volvo 360 to get a 20l bottle from it for the drained oil. And this happened:
See the 360 users' rides thread for more gory boring details :-)
Definitely doing a high compression hot cammed ITB equipped engine using the third DOHC head that I have! :-D
150hp stock, somewhere up toward 200hp @ crank should be easy enough to get.
Oil dump pics from today:
https://twitter.com/FredCookeNZ/status/ ... 9484936192
https://twitter.com/FredCookeNZ/status/ ... 4912523264
https://twitter.com/FredCookeNZ/status/ ... 2465253377
Sat Nov 11, 2017 11:55 am
Got around to finishing the strip down job last night and found some interesting things :-)
https://twitter.com/FredCookeNZ/status/ ... 6115707904
https://twitter.com/FredCookeNZ/status/ ... 0403792896
https://twitter.com/FredCookeNZ/status/ ... 3328394240
https://twitter.com/FredCookeNZ/status/ ... 4182633472
https://twitter.com/FredCookeNZ/status/ ... 5311934464
https://twitter.com/FredCookeNZ/status/ ... 8133963776
https://twitter.com/FredCookeNZ/status/ ... 3749957632
https://twitter.com/FredCookeNZ/status/ ... 0261859329
https://twitter.com/FredCookeNZ/status/ ... 4373441536
https://twitter.com/FredCookeNZ/status/ ... 5271394306
https://twitter.com/FredCookeNZ/status/ ... 3002913792
https://twitter.com/FredCookeNZ/status/ ... 4676919296
https://twitter.com/FredCookeNZ/status/ ... 6367968256
https://twitter.com/FredCookeNZ/status/ ... 5404478464
https://twitter.com/FredCookeNZ/status/ ... 5513650176
https://twitter.com/FredCookeNZ/status/ ... 4830191622
https://twitter.com/FredCookeNZ/status/ ... 0656000000
https://twitter.com/FredCookeNZ/status/ ... 6760849409
https://twitter.com/FredCookeNZ/status/ ... 5326520321
https://twitter.com/FredCookeNZ/status/ ... 0436489219
https://twitter.com/FredCookeNZ/status/ ... 6296712193
https://twitter.com/FredCookeNZ/status/ ... 0449901569
https://twitter.com/FredCookeNZ/status/ ... 0567203841
https://twitter.com/FredCookeNZ/status/ ... 6292467712
https://twitter.com/FredCookeNZ/status/ ... 7975877632
https://twitter.com/FredCookeNZ/status/ ... 6266862592
https://twitter.com/FredCookeNZ/status/ ... 6538633216
https://twitter.com/FredCookeNZ/status/ ... 2473857024
GASP! Too many tweets. Too many photos. Too much copy paste of URLs.
Cheap spare B234F fully stripped down! Time to organise the parts and move toward a built engine scenario.
I need to snap a couple of extra photos and upload, but in a new post. Give me a few...
Thu Nov 23, 2017 4:34 am
Cleaned the sump and other bits...
https://twitter.com/FredCookeNZ/status/ ... 1380080640
Thu Nov 23, 2017 5:18 am
Magnetic drain plug test fit:
https://twitter.com/FredCookeNZ/status/ ... 4970795009
Thu Nov 23, 2017 11:19 am
A little progress on this the other evening, finally got around to collecting the tools required and splitting the rod caps off the rods:
https://twitter.com/FredCookeNZ/status/ ... 9349282817
Sun May 20, 2018 7:25 am
