View unanswered posts | View active topics It is currently Wed Jun 19, 2019 4:11 pm
Reply to topic  [ 3 posts ]
Thermal barrier between cylinder head and intake manifold.
I know there are loads of variables like IAT, manifold temperature, volume, cross-sectional area, air speed, level of laminar flow, wet/dry air, driving style... But to generalise horribly, for a daily driver that gets a frequent spanking, is it worth $60 for a phenolic/similar spacer?
Wed May 28, 2014 2:01 pm
I doubt it. My manifold is heavily heated on purpose. Because of this the fuel pouring through it is vapourised effectively and it runs great. I doubt there's much time for the tiny outer layer of air to be heated and mixed as each cylinder gulps in a mouthful ;-) At low loads/airflows you don't care. At higher loads/airflows it's a tiny percentage.
Thu May 29, 2014 7:23 am
Yeah I assumed if I spent $60 improving my intercooling it would have a larger effect. I wondered if anyone knew otherwise because it's such an easy addition to make and if I bought one I'd probably have a go at 3D printing a plastic diffuser plenum manifold. Bodged stock manifold and paper gaskets it is :-)
Thu May 29, 2014 9:56 am
