Sensor And Logging Ideas
Posted: Tue Oct 22, 2013 1:41 pm
Ideally, a datalog from a car will contain EVERYTHING that you could possibly measure about that car, period. This isn't practical, but creating a thread with such a listing might be. So I'm going to try, with your help. I'll update this first post with everyone's suggestions, at my discretion.
All normal engine parameters are a given. Don't bother with the core stuff, though I may list some. Extra parameters, though, fire away.
Engine Bonus Sensors
- Oil Pressure
- Oil Temperature
- Fuel temperature in rail
- Fuel temperature in tank
- Fuel pressure at pump
- Fuel pressure in rail
- Fuel pressure post regulator
- Turbo RPM
- Wastegate position
- Exhaust back pressure sensor
- Wideband per cylinder (mostly NA engines)
- EGT per cylinder
- Ambient air temperature (normal NA IAT signal)
- Ambient air pressure (normal AAP signal)
- Pre-intercooler air temperature
- Pre-intercooler air pressure
- Post-intercooler air temperature (normal boosted IAT signal)
- Post-intercooler air pressure
- Across throttle pressure drop
- Across intercooler pressure drop
- Across turbocharger pressure gain
- Manifold air temperature
- Manifold air pressure (normal MAP signal)
- Steering angle
- Brake pedal in use/not
- Brake line pressure, front and rear
- Handbrake handle angle and/or cable pressure
- Clutch switch and/or pedal angle and/or hydraulic pressure and/or actuator angle
- Gear selection sensor
- GPS positions (front and rear)
- 4 * shock pots
- 4 * wheel speed sensors
- N axis accelerometers (more than one for attitude determination)
- Gyroscope
- Door locks
- Key position
- Window positions
- Seatbelt plugged/not
- AC on/off
- Fan on/off/high/low/duty
- Rear window heater on/off
