Muffler Ideas For The Mighty Red Truck, FreeEMS #2
Posted: Sun Oct 06, 2013 6:29 pm
My current setup is efficient, sounds good, and isn't horribly loud, but is for sure louder than I'd like it to be. It looks like this:
My plan, for years, was to double back, and add one or two more mufflers, then exit much as it currently does. Today out of chance I found a muffler design that I kinda liked and searched around a bit to find similar stuff. Turns out they call them "twin loop" mufflers, and are HOT with the JDM, YO crowd. I don't mind that. I'm not a ricer, and I know it, so I don't care what others think. The benefit to these designs is full straight through flow and more muffling, but the draw backs are more length, more bends, and more weight.
What I might try to do is fabricate my own up to save weight, as standard mufflers use quite thick steel and are pretty heavy. The thing with going lighter gauge is that if there is much pressure in the thing, it can blow the sides out. I've seen this done to an HKS muffler with 160hp, not cool. To mitigate that is as simple as using only round tube to do the body. Be it one big round tube rolled from s/s sheet, or three small ones isn't too important.
Thoughts, ideas, and abuse welcome.
