That's the wheel involved, post machining, pre tests. Before machining it had pointy triangle teeth. DIYAutoTune sell them that way. :-o
The values for the stretch before during and after missing from the LA screeny are here:
2.82475
2.772
2.8385
7.3986875
1.9526250
3.1124375
3.012
3.0403750
As you can see, things don't look right.
What should be close to 1:1, 1:1, 1:1, 1:1, 1:2, 2:1, 1:1, 1:1, 1:1, 1:1 is wildly different. The trouble isn't the slightly wider missing, it's the combination of wide missing and narrow post missing. If you compare the long with the average you get ~3.8, but if you compare the wide with the narrow after it you get ~10 :-o
Sure as the sun will shine tomorrow, the error code was: 66, or TooWideNarrow which I've aliased to the name noiseAppearedWayTooEarlyAsIfItWasAVRToothButWasnt because that's the most likely cause.
DIYAutoTune FTL.
