Solutions To Stop Bolts Backing Off
Re: Solutions To Stop Bolts Backing Off
That gives you nut retention, but doesn't ensure your nut stays tight. If the nut is under any serious load, having it back off will cause damage, possibly stud breaking damage.
Original: http://www.schnorr.com/downloads/techni ... /file.html
Cached: http://stuff.fredcooke.com/NordLockVers ... shers.pptx
This is the other type that appears better than the NordLock wedge type: http://schnorr.com/products/safety-washers.html
DonTZ125
Yamaha likes splined fold-over washers on the drive sprocket and clutch hubs, with high tightening torques and loads. Of course, you're talking a 20-25mm splined shaft with a thread for the retaining nut, not a 6mm bolt.Fred wrote:That gives you nut retention, but doesn't ensure your nut stays tight. If the nut is under any serious load, having it back off will cause damage, possibly stud breaking damage.
