New Product from TTR - Speedo Corrector
Comments, discussions, links about/to suppliers of goods and services related to DIY Engine Management Systems.
DonTZ125
Post by DonTZ125 »
When you change your rims, or tires, or diff, your speedometer usually doesn't read as accurately as it used to. Sometimes this isn't a big deal, sometimes it is - certainly, the nice policeman doesn't want to hear about how all the mods you've made have thrown off your speedo!
We now offer a small, easy to use module that wires in between your speed sensor and the speedometer, and allows correction to put the readout back where it should be. Using a single multi-turn pot, stepless adjustment can be made from 2.5% to 250% of the input frequency. Calibration test points inside the housing allow the use of a multimeter to quickly dial-in the adjustment.
The Speedo Corrector will sell for $60, and can be ordered here.
Re: New Product from TTR - Speedo Corrector
I removed your other thread and issued you with a warning because I found it insulting and lazy. You may repost it properly, if you wish. Don't be lazy.
DonTZ125
Post by DonTZ125 »
Acknowledged and understood. As I said in a pm reply to the warning, I generally try to avoid egregious stupidity ...
Thanks for being cool! :-)
