View unanswered posts | View active topics It is currently Fri Oct 23, 2020 12:24 pm
Reply to topic  [ 216 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8 ... 22  Next
EMS quote of the day competition
Yeah, OK, just making sure :-) I saved the page anyway, so if it goes, then I have a record. I have a long record of almost everything ever posted. Some of the long gone stuff was quite interesting at the time.
Admin.
Tue May 20, 2008 9:55 pm
I used to do that with email subscription but it's no longer available. What was very interesting was seeing the initial uncensored version of each post without having to be on the forum 24/7. There's quite a lot of things that disappeared due to censorship or pruning and not just "offensive" stuff but also a lot of good technical data.
Jean
Wed May 21, 2008 12:32 am
*Poof!*
And like that it's gone.
Wed May 21, 2008 1:08 am
Exactly :-( my main reason however was that google didn't index msefi due to the robots.txt file reading "Go away!!" (as if the robots read it LOL), so I used gmail as a MegaSquirt search engine of sorts that included the pruned and edited and deleted and moved stuff as some icing/bonus :-)
GartnerProspect wrote:
*Poof!*
And *Poof!* it's back :
goaman wrote:
http://www.VEMS.hu/wiki/index.php?page=PdaCockpit
It's look very nice and there are some tuning capabilities.
Anyone testing it with MS ?
Sorry if it is wrong place to a post but there is no section for Win devices. :oops:
renns wrote:
Looks like a neat application. I'm sure with a bit of tweaking it could be configured to suit MS. Unfortunately, the invisible forum mods hacked your link, likely basing it on rule #1 of the FAQ, although I personally don't see it necessary in this case. For those wanting to see the page, google pdacockpit, and you'll find it in a flash. The Orwellian touch around here can sure be a turn-off at times.
http://www.msefi.com/memberlist.php?mod ... le&u=19772
Another potential MSer going "wtf? my login doesn't work anymore!"
RIP goaman
Wed May 21, 2008 7:19 am
It's quite ironic to have a post mention Orwellian touch disappear even though the "official" reason is probably the mention of the big evil VEMS (nice touch with the edit there ;) ).
Jean
Wed May 21, 2008 2:24 pm
I actually didn't even think of it like that :-) I just thought, the link is broken, fix it. I also had to fix the rules link as it didn't copy paste across (no wysiwyg editor here). You are right though, it illustrates the difference nicely doesn't it :-) i.e. I have no financial/pride interests to protect by filtering information... I did note that VEMS is mentioned and not deleted on ms3efi.com already. That is a positive change :-) I also noted no user called Lance over there. Someone should sign up as Lance for a laugh :-)
Wed May 21, 2008 3:52 pm
http://www.ms3efi.com/viewtopic.php?f=6&t=3&p=142
KeithG wrote:
Sounds great! This forum/thread has gome pretty dead, though. What happened to the videos? Is there any discussion we can be a part of, or is all this going on 'behind the curtain'?
Jerry wrote:
At this point James is testing some of the proposed injector driver hardware on the bench, the holdup has been getting together some hardware to replicate some worst case scenarios (8x1.x ohm injector scenarios...).
KeithG wrote:
Like I said, Sounds great. What driver circuit is he testing? What input circuit is proposed? I am of the opinion that more eyes are better. We do not want to derail anything, but would like to know what is going on. Can you leak a little of this, or am I just too far in the dark and this is published somewhere else that I have not found?
Nice work there! I wonder if they will catch on and involve the potential user base such that peoples ideas and constructive criticism can get through and make a positive difference to the end product?
Not pointing the finger here, but if James had made a thread about his testing others would have read it and could have offered potential solutions to his load issue. This *could* have sped up the process and/or made it more reflective of actual use cases. Maybe he has the optimum solution already? He's a talented guy, so probably, but maybe not also.
Doesn't quite fit with this from Bruce on April 13 does it...
Bruce wrote:
And we want this effort to reflect the desires of users and not be completely dictated by B&G and others.
Bruce wrote:
but we want you to be more of the driving force.
Wed May 28, 2008 7:50 pm
Bruce wrote:
James has an eval board to test this circuit which he is in the process.
... of doing?
Bruce wrote:
The heat generated is a bit more than what is desired and more tests to see if it is in the flyback (avalanche) or in the recirc mode - more tests are needed before a definite answers comes out.
More tests - more tests.
Bruce wrote:
Also, with the sampled points a mechanism to dump the data back is also useful for detecting and analyzing polarity issues and noise.
Also, also.
Bruce wrote:
I have test code on the MC56F8013 DSP and I am also testing the STM32 as well
I am also as well.
Is Bruce (In order of increasing probability) :
A. Uneducated?
B. Lazy?
C. Busy?
D. Tired?
E. Angry at what Keith said?
My vote goes towards E.
And, this just sounds like trouble to me :
Bruce wrote:
For the tach input, one thing I am looking at is what was proposed at the MegaMeet a year ago, the "Direct Digital Sampling" method (pat. pend).
I'll have to look up that patent application for a laugh. The last one was certainly laughable. This one just seems frivolous and pointless - LM1815.
Thu May 29, 2008 12:09 pm
"You can't build a reputation on what you are going to do." - Henry Ford
I guess that applies to me and this site Image
Thu May 29, 2008 4:23 pm
"Tyres that grip in the wet" - Radiohead (Fitter Happier, OK Computer)
I must have listened to that song 10000 times and never heard that till just now!
Tue Jun 03, 2008 10:03 am
