What does that mean?pro: much harder (impossible?) to money-shift
True!con: (at least on bimmers and other cars with exh manifolds on the pass side) very hard to route turbo plumbing
Not so true. Most people have significantly better motor skills in the hand they use more often. Ability to control with finesse is important when you are going properly fast :-)Oh yea and you don't need your steering hand to be stronger, unless you don't have power-steering.
Reality : which ever one you get used to you will also get good at :-)
