malcom2073 wrote: Can you upload the .bin and .meta.json log files from the emstudio directory?
Are .bin and .meta.json log files created on a winblows install?
malcom2073 wrote: Also, if it does the same thing both with and without the ECU connected, I'd guess that perhaps it's pointing at the wrong com port?
I checked the COM port in winblows and it is correct (COM1) I'm using this laptop as it has a built in serial port to eliminate any adapter issues.
malcom2073 wrote: If you're on linux, and have it pointing to a pty, that can cause that issue.
Testing is what I'm here for, so I grabbed one my other laptops that's loaded with Debian and attempted a install of EMStudio, but failed at that also, I see there is information on installs for poobuntu.... any chance some info on whats needed to build this on Debian.
Fred wrote: Dying is fine, and good, but it should fail slow and report everything it can about what it found as a diagnostic rather than leaving the user wasting your time and mine on the forum like this
A step by step of what's happening might be cool too in a sort of console window while loading. MTX does that and I quite like it. Much like Linux booting up without a splash screen.
Checking xyz... OK.
Checking abc... OK.
Requesting version... "blah", OK.
or whatever.
I second that... I have no idea if it's me being a retard (highly likely) or just a software issue.
Also I have noticed that when I open EMStudio the lower and right hand side of app is off the screen.
If I select edit --> settings : the window has to be stretched to show the buttons.
I will try and get some screen shots and upload them shortly.
Preston.
