View unanswered posts | View active topics It is currently Wed Feb 19, 2020 3:33 pm
Reply to topic  [ 32 posts ]  Go to page Previous  1, 2, 3, 4  Next
EMStudio, YATA(Yet Another Tuning Application)(was FreeTune)
malcom2073 wrote:
Kennybug wrote:
Installed in winxp32. a VC++ library was missing.
need install this as well
http://www.microsoft.com/en-us/download ... px?id=5555
Good catch, forgot to mention that. I'll see about adding that to the installer.
If this had been added to the installer, it would have saved me 10 minutes this morning, and would have saved Fred some wrist damage. :)
Edit: It works for me.
BenFenner's 1994 Black SE-R
BenFenner's 2000 Black M-Coupe
Fri Jun 15, 2012 1:46 pm
My apologies, I'll try to get that added to the installer :)
EMStudio
Interesting Stuff
My Car
Fri Jun 15, 2012 3:50 pm
Name is now officially EMStudio: http://malcom2073.github.com/emstudio/
EMStudio
Interesting Stuff
My Car
Fri Jun 15, 2012 11:01 pm
For the serial, you should really check http://gitorious.org/qserialdevice . it's a very good library.
Wed Jun 27, 2012 4:09 pm
There are at least two other libraries for QT too. I've no idea if they're good or not, though.
Wed Jun 27, 2012 6:04 pm
The thought had occured to me to use an external library, however I wanted to reduce dependancy size for Windows, and serial is simple enough.
EMStudio
Interesting Stuff
My Car
Thu Jul 05, 2012 3:41 am
Surely it could get bundled into an installer as part of your auto-build, though, no?
Thu Jul 05, 2012 10:12 am
Yes, I could compile it, and set the installer up to pull it in. It's a hassle, for something that really takes 6-7 lines of code and garuntees that I retain control over exactly how the serial port is used. I've used serial libraries before (Qxt and QSerial both) and had issues with them, so I just spend the extra 10 minutes writing my own code every time I need to do serial stuff.
EMStudio
Interesting Stuff
My Car
Fri Jul 06, 2012 12:24 am
Post edited:
Spudmn wrote:
do
EDIT: Do NOT do the -project qmake execution, it is not necessary most of the time and can/will break your build. Fred.
Code:
 qmake -project << don't do this, normally.
qmake
 make
This stuff is either completely irrelevant and old, or just for GCC builds on Windows. In any case, do NOT do this on Linux, you don't need to, and it will break your build and cause you and me headaches.
Tue Jul 10, 2012 3:36 am
Linux install:
Code:
sudo apt-get update
sudo apt-get install libqt4-dev libqt4-opengl-dev qt4-qmake libqwt-dev libqt4-declarative libqjson-dev
Tue Jul 10, 2012 3:37 am
