EMStudio, YATA(Yet Another Tuning Application)(was FreeTune)
malcom2073
So I started working a bit on a Qt/c++ based datalog/live display application for FreeEMS. I eventually want to also work tuning into this application.
I started playing around with this about a week ago, fiddling around with just playing back logs with a lot of help from Fred fortunately, which made it go very quickly. He did a bit of explaining about the serial protocol involved, so with that and the OLV source code for value reference I managed to get the ability to listen to live data integrated. The serial code wasn't quite working properly though, and Fred tried it a couple of times for me without success. I happened to be in the Phoenix AZ area, and seank-efi graciously offered to let me stop by and check out his FreeEms setup. Once I got there, he showed me the hardware and let me attempt to connect to it on the bench with my application. Some thorough debugging later and I got live data to read properly! We took a video of the software running next to his dev board on top of the car http://www.youtube.com/watch?v=ZeYnkznv ... e=youtu.be
Seeing this, made me even more enthusiastic about FreeEms and pretty much sealed the deal for me using this in my car. So I've decided to continue development of FreeTune, and hopefully have it become a truly useful cross platform datalogging and tuning application.
Official name is now EMStudio, and official website is http://www.emstune.com (emstudio.com was taken damnit)
Windows 32bit installer: (Recommend getting that latest, always at the top)
http://mikesshop.net/EMStudio/
Source code:
http://github.com/malcom2073/emstudio
Website:
If I haven't gotten to putting the notice in by the time this post gets read, it is, and always will be GPLv2. I may extract the base communications library to be lgpl if I see a need, but at the moment it will remain a core part of the main application.
And as another note, until further notice, master branch is considered unstable, until I have an actual stable code base to go off of, then I'll branch off for development. I expect that's going to be a month or so. Feel free to hit me up here or on irc (mal|lappy) if you're interested in using it, or just give it a shot. I can't guarantee it won't ruin your tune or corrupt your memory until it's considered stable, but if you talk to me first I can probably advise you as to the dos and don'ts. Eg: don't use the "write ram block" button, it's not correctly set up yet!!, course there isn't one yet but that sort of thing.
Source code:
Website:
- Kennybug
Re: FreeTune, YATA (Yet Another Tuning Application)
excellent to hear about the new tune/log app!
So am I.malcom2073 wrote:Seeing this, made me even more enthusiastic about FreeEms
I can! Well, at least the memory part. You can't access memory directly, only through my gateway with lots of checks. You'd have to get quite (un)lucky to send garbage to a main table AND have it make it in successfully.malcom2073 wrote: I can't guarantee it won't ruin your tune or corrupt your memory
New name idea: 24Tuner why? Because you wrote the working base in 24 hours :-o
- Spudmn
Hi Malcom2073
Great job.
One tip for people trying to compile it.
do
EDIT: Do NOT do the -project qmake execution, it is not necessary most of the time and can/will break your build. Fred.
If you get this error
then you need to add to the freetune.pro file.
I don't know why qmake doesn't add this automatically.
I think that you will also need at least QT 4.7. I am testing it on 4.8.
Great work. Keep it up.
Lots of cool graphs please. Data logging is my bag baby
edit: added qmake
Great job.
do
qmake -project << don't do this, normally.
qmake
makeCode: Select all
fatal error: QDeclarativeItem: No such file or directoryCode: Select all
QT += declarativeI don't know why qmake doesn't add this automatically.
edit: added qmake
Reason: Clarify code snippet validity.
malcom2073
Thanks!Spudmn wrote:Hi Malcom2073
Great job.
That's my bad, I'll fix that. Not sure why it's assumed on my machine, but it should be there regardless.Spudmn wrote: One tip for people trying to compile it.
doIf you get this errorCode: Select all
qmake -project make
then you need to addCode: Select all
fatal error: QDeclarativeItem: No such file or directoryto the freetune.pro file.Code: Select all
QT += declarative
Right, at least 4.7.0. I use 4.8.0 as wellSpudmn wrote:I think that you will also need at least QT 4.7. I am testing it on 4.8.
Thanks again! graphs are pretty low on the list, since OLV will be able to load logs that you take with FreeTune.Spudmn wrote: Great work. Keep it up.
IMO: Tuner should focus on tuning, gauges/bar graphs, on/off lights, overlays, real time stuff. Log viewer/post analysis should do fancy display of old data over time. OLV will eventually grow into something fairly powerful for looking at recorded data. I think it dilutes a tuner to handle that too.
malcom2073
Development Windows binaries will be built here: http://mikesshop.net/FreeTune/
I can't guarantee they will work, so talk to me before trying one, they're automatically built as I commit changes in the development branch.
- Kennybug
Installed in winxp32. a VC++ library was missing.
need install this as well
http://www.microsoft.com/en-us/download ... px?id=5555
malcom2073
Good catch, forgot to mention that. I'll see about adding that to the installer.Kennybug wrote:Installed in winxp32. a VC++ library was missing.
and for those like me who have 64-bit windows!
http://www.microsoft.com/en-us/download ... x?id=14632
