Off the top of my head I think I'm using "debian squeeze 6.0.4"
When I apt-get install I can not find "libqt4-declarative" as per the EMStudio website is that also my retardedness? An yes I did update first
Preston.
I like this statement! This should be added to something like a FreeEMS commandment set or something....Fred wrote:If you're not using unstable, you're using something out of date.
As Fred said, use something new. Less than a year old or so, so yeah Debian stable is forever out of the question, sorry.Preston wrote:Ok, as in how new?
When I apt-get install I can not find "libqt4-declarative" as per the EMStudio website is that also my retardedness? An yes I did update first![]()
Preston.
Should be, but only after you've managed to connect. If you don't see them, then you're not connecting at all.Preston wrote:Are .bin and .meta.json log files created on a winblows install?
Excellent. So we've ruled that out, my next guess would be that something else is messed up. Perhaps try Megatunix? If you're not generating .bin files, then you're not connecting to the COM port, so I assume something is phyiscally or driver-wise broken (The latter not likely with a hardware serial port)Preston wrote: I checked the COM port in winblows and it is correct (COM1) I'm using this laptop as it has a built in serial port to eliminate any adapter issues.
See my above post, upgrade to a newer OSPreston wrote:Testing is what I'm here for, so I grabbed one my other laptops that's loaded with Debian and attempted a install of EMStudio, but failed at that also, I see there is information on installs for poobuntu.... any chance some info on whats needed to build this on Debian.
Yeah I need to fix window sizes on windows. And a more descriptive interrogation debug view is pretty much top of my list once I have more free time to code again.Preston wrote:I second that... I have no idea if it's me being a retard (highly likely) or just a software issue.
Also I have noticed that when I open EMStudio the lower and right hand side of app is off the screen.
If I select edit --> settings : the window has to be stretched to show the buttons.
I will try and get some screen shots and upload them shortly.
Preston.
