Yeah, I set the default in the code to be 16 16 for you a while back, all tables are that now, though in future if a tuning app supports it they could easily all be different and the firmware wouldn't care.
the lambda table is 6
the ignition table is 8
the format, size, structure, offsets, are all the same, only the location id and the cell value/unit transformations are different. details for that copy/paste from above:
"ign timing table same as ve but cells are raw/1024 = deg btdc and lamda, cells same as var returned?"
meaning:
* a lambda cell has /32768
* a ign cell has /1024
What did you mean with "(18:10:56) Dave: number don't change in the gui properly either, but i'll fix that tomorrow maybe" ? I guess I'll find out soon
