Can anyone commit to keeping the RTV maps up to date in MTX? pretty simple stuff provided i change things gradually on the firmware side. Today they're out of sync, as is OLV, and both require a small change. I'll get to it soon, but if someone wanted to take that on it would save me some time, assuming they could be fairly prompt. Half of the time I'll have to update it to test my work anyway. So I guess it's not overly important, but it could still help a bit.
Wanted: Real Time Vars Map Maintainer
Re: Wanted: Real Time Vars Map Maintainer
Details on the missing data:
http://docs.freeems.org/doxygen-html/dd ... 6830760306
http://docs.freeems.org/doxygen-html/d8 ... tml#l00165
injection cuts and ignition cuts, those fields and 4 bit flags from them, are missing from mtx. I'm working on olv right now. If you want limiter/cut flags in your mtx UI or mtx logs, someone had better step up, because I ain't doing it anymore :-)
OLV is now up to date: viewtopic.php?f=54&t=1639&p=25497#p25497
dandruczyk
Provide the offsets of the values you want within the log stream block. Your docs you linked to don't make it clear at all.
dandruczyk
NM, I think I found it... Please document how your want the flags displayed on the runtime status window.
dandruczyk
Added (guessed), doesn't seem to work right, flickers like hell. Test it... More complete information would make this process work better...
The firmware wasn't as I thought it was and OLV didn't work either. So I just fixed the firmware to work as I thought it did. However, OLV showed just zeros, no noise, so not sure what you're seeing there. Try with the latest hash: dccba2de121f957b9042133645e98efb2b9b60d6
Your latest hash seems fine on this machine lighting up correctly as the RPMs sweep past and back.
